clear corner problem
Old 01-23-2004, 07:15 AM
JASON5's Avatar
i have some of the euro clear corners and they keep getting moisture in them and it builds up, is there anyway to fix this problem thanks
JASON5 is offline
Old 01-23-2004, 08:40 AM
Jilly's Avatar
Get rid of them.
BTW, try the Appearance Section.
Jilly is offline
Old 01-23-2004, 08:52 AM
Moderator
PhantomTA's Avatar
Originally posted by Jilly
Get rid of them.
Wanna be a mod Jill?
PhantomTA is offline
Old 01-23-2004, 09:30 AM
AxeGrinder30thZ's Avatar
I don't know what to tell you. I have clear corners and they never get moisture or anything in them.
AxeGrinder30thZ is offline
Old 01-23-2004, 09:49 AM
Jilly's Avatar
Yeah. You're slacking on the job so I gotta take over.
Jilly is offline
Old 01-23-2004, 12:08 PM
ppmz28's Avatar
The only thing i can think of is that somewhere they aren't sealed good, or a crack in them in the back or front. Did you put the rubber seal in with the light bulbs?
ppmz28 is offline
Old 01-23-2004, 04:16 PM
joSShua's Avatar
That happened to mine when I first put my clear corners in. Its just a bad seal. Make sure the bulb harness is seated and snuggly fitted into the hole. Rubbers gaskets also must be used.
joSShua is offline
Old 01-24-2004, 02:28 PM
bigde4u's Avatar
Get rid of them.
tisk, tisk always sooo negative.
I have some and they don't get moisture in them. Check the around the bulb and you could even put a seal around the joints in the light.
bigde4u is offline
Old 01-24-2004, 08:14 PM
Jilly's Avatar
Not always. Just most of the time.
Jilly is offline
Old 01-24-2004, 08:30 PM
bigde4u's Avatar
bigde4u is offline
brandboZ28
01-31-2003 06:19 PM
silver97Z
09-11-2002 03:17 PM
AW/whiteZ-28
08-27-2002 12:53 AM
AW/whiteZ-28
08-22-2002 11:53 PM
Absolute Z28
07-19-2002 02:21 PM
Quick Reply: clear corner problem
