??? about VFN fiberglass 2 inch cowl hood for 95 Camaro.
Old 08-09-2009, 12:46 PM
toomchz4u's Avatar
I picked up a VFN fiberglass 2 inch cowl hood locally last week for $230 from this chick that sold her car. Its in perfect condition. In the process of installing the hood I have noticed that my stock bolts for the hook beside the latch and the bolts on the bottom of the hood (up near the wipers) will not screw in all the way. The stock bolts for the struts and the latch which are smaller work perfectly. Anyone with a VFN hood know if there are special bolts that come with these hoods from them to install on these cars??? I called them but I talked to some chick who claims there isn't and I can use my factory bolts but I'm not trusting her response because I can't get them to tighten at all and I don't want to damage the hood trying to get them tight.
toomchz4u is offline
Old 08-09-2009, 12:55 PM
DeLaRosa25's Avatar
should be direct bolt on? I have the 2" VFN cowl in my shed waiting for paint. Guess I should take a closer look.
VFN sucks W/ customer service. They dont know ****
DeLaRosa25 is offline
Old 08-09-2009, 01:58 PM
toomchz4u's Avatar
If I'm not mistaken somebody had 1 of these for sale recently in the for sale section and I believe they mentioned something about special bolts that came with this from VFN. Anybody else wanna chime in??? I'm planning to call them back or email them tomorrow.
Old 08-09-2009, 06:13 PM
shock6906's Avatar
Make sure you're not cross-threading.
shock6906 is offline
Old 08-09-2009, 07:41 PM
toomchz4u's Avatar
I'm pretty sure they aren't crosthreaded. Its 4 bolts and they get to a certain point and won't go any further. They are nowhere near tight. That's what's leads me to believe they are the wrong bolts for this particular hood.
Old 08-10-2009, 03:09 PM
DeLaRosa25's Avatar
That would suck if the bolt thing is true. I didnt get any
Old 08-10-2009, 06:00 PM
toomchz4u's Avatar
Delarosa25 you bought yours new from VFN??? Or did you buy yours used like me??? If you bought yours new and it didn't come with anything then that answers my question I guess...
Old 08-11-2009, 10:23 AM
Z28SORR's Avatar
Measure the depth of the hole, then measure the lenth of the bolt, if they"re to long BUY SHORTER ONES!!!
Z28SORR is offline
Old 08-11-2009, 10:05 PM
DeLaRosa25's Avatar
Brand new. Shipped to my house. Even gave me stickers lol
Old 08-12-2009, 03:00 PM
endo's Avatar
DO NOT USE YOUR FACTORY BOLTS-They use 5/16" Standard bolts for the backs and 1/4x20 for the struts and latch, if you use your regular factory bolts they will strip out the inserts in your hood,
endo is offline
Old 08-12-2009, 08:11 PM
toomchz4u's Avatar
Thanks for the responses fellas it looks like I may be fu--ed with this but I will try to get the stock hood bolts out tomorrow and see if I have messed the hood up.
Old 08-13-2009, 12:08 AM
DeLaRosa25's Avatar
PLZ post up what happens. I would like to be prepared for when I install mine
Old 08-13-2009, 09:52 AM
endo's Avatar
You Guy's should call them and ask them to send you each a set of bolt's its the least they should do!
endo is offline
Old 08-22-2009, 12:48 PM
ur jlus's Avatar
I will check with the body shop that is installing mines on monday. I will post to let you know about bolts.
ur jlus is offline
Old 08-24-2009, 11:30 PM
toomchz4u's Avatar
Thanks but I've already found out that the stock bolts do not work. Endo gave the correct sizes above. Learned an expensive lesson with this as I have ordered a brand new flat fiberglass hood from vfn that should be here in a couple of weeks.
bowtieboy95
07-01-2015 06:49 AM
k1996z28
04-06-2015 11:55 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
RedLineRev
01-23-2003 03:51 PM
phantasm99
08-28-2002 11:01 PM
Quick Reply: ??? about VFN fiberglass 2 inch cowl hood for 95 Camaro.
