95 z28 starts then stalls
Old 11-19-2011, 11:27 PM
duker's Avatar
so ran through a puddle took it apart replaced icm, coil, ngk plugs, opti of the distributor and ect sensor. car actually started but shuts off in 2 seconds. i used to have smoke coming from intake but now it dosnt anymore after messing with egr by tapping it. car is running real rich and to be hnest im at wits end. its throwin a maf code but i know if you unplug it it goes into a fail safe mode...so im thinking it is the egr vaccume or timing..can i have some expert help and advice before i take it to a shop for somone else to do it.
duker is offline
Old 11-20-2011, 12:42 PM
Re: 95 z28 starts then stalls
This is the wrong forum for this topic. It needs to be posted on "LT1 Based Engine Tech". In fact, you already have it posted there.
In fact, several people have already responded to your other posts, trying to help you. Did you even bother to go back and read the responses that people gave you?
Post the problem ONCE
Post the problem ONLY on the CORRECT forum.
Do not double post on the WRONG forum. Paticularly after the post has been moved to the correct forum by the Moderator, who then explained that you only need to post on the CORRECT forum.
https://www.camaroz28.com/forums/sho...d.php?t=840355
https://www.camaroz28.com/forums/sho...d.php?t=840170
PLEASE cooperate.
Injuneer is offline
Noenav
03-01-2019 07:38 AM
tds1213
11-27-2014 12:55 PM
thenewkid
11-27-2014 09:41 AM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: 95 z28 starts then stalls
