cutting springs
Old 06-14-2004, 02:47 PM
buffalo bill's Avatar
cutting springs
is it possible to cut the springs on a 3rd gen camaro?
has anyone ever done it before?
buffalo bill is offline
Old 06-14-2004, 03:32 PM
do you cut them at the top or bottom?
and can i cut the front and back( all 4)?
p.s. i am completely retarded when it comes to suspension.
Old 06-14-2004, 04:45 PM
PyRo9862's Avatar
Lowering your car you should get LCA relocation brackets, and just spend the money for lowering springs, they arn't expenisive. Do new shocks and struts while your at it, they have to come out anyway. Throwing in some bigger swaybars, and putting poly bushings in while your suspention is half apart isn't a bad idea either. Ok, your free job just went up to $800 or so, but it pays to do it right, and you will definatly feel a big differance
While your spending that much throw in a wonderbar ($10 or so), and an STB, 3pts start at $130. Stuff adds up quick
PyRo9862 is offline
Old 06-14-2004, 04:59 PM
IROC-T's Avatar
LOL! you forgot the SFC's
IROC-T is offline
Old 06-14-2004, 10:06 PM
PyRo9862's Avatar
Damnit, add another $300
A good set of tires to $1000
PyRo9862 is offline
Old 06-14-2004, 10:39 PM
aklim's Avatar
I thought it was a bad idea to cut progressive rate springs?
aklim is offline
Old 06-22-2004, 09:24 PM
jconrad's Avatar
Yeah, I also would not recommend cutting the springs. It will change the spring rate, and not for the better, either. lol
jconrad is offline
Old 06-24-2004, 06:52 PM
slimdawson's Avatar
I didn't know progressive rate springs came on Camaros.
There is nothing wrong with cutting springs. It will increase rate which is good when the springs have less distance to travel. Just take your time and cut 1/2 coil off at a time. Put them back in, and check height. It is harder to make the spring longer than it is to make them shorter.
slimdawson is offline
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
cmdeshon
12-12-2014 10:51 PM
Quick Reply: cutting springs
