Z06's did NOT fit!!!!
Went to have the rims put on today. Fronts went on perfectly. Rears (18x9.5 Z06) wouldn't fit. The center wouldn't clear the hub and therefore the studs didn't have enough thread to catch and the rim wouldn't have a completely flat sitting surface.
As of now, tomorrow morning I'm going to grind the hub down enough to slide the wheel over it. I'd be suprised if it's a 32nd" that needs to be ground. So close, so close.
What did all yall with Corvette wheels do?
NOTE: The front (17) and rear (18) centers are the same. I.E. The front center won't clear the rear hub either.
Appearantly it's a common problem with using newer wheels on the older rearends. Just bust out the dremel and sand paper and go to town. And don't forget the digicam while you're at it.
http://web.camaross.com/forums/searc...by=&sortorder=
Chris!!! Thanks man! Holy crap that is a relief. No pics yet, but while the car was on the lift with fronts installed and rears hanging....the car was glorious.
I'll hit you back tomorrow night with pics. Take it easy.
Its just about 1/32"..... 0.030" to be exact. That's how much larger the rear hubs are than the front hubs, up until late 96 or early 97 models. Most people grind/sand the inside diameter of the opening in the wheel.
UPDATE
Ground the driver's side hub, not enough obviously. I put the pass wheel/tire on (clear on drivers was drying where a little chrome started chipping). I tightened it down and now it's stuck on there. I mean STUCK!
I ***-a-long'ed my wheel/tire to the rear wheel on my little brother's Bird and it just pulled my car (on jack) so I stopped. That's how much pressure there is. What can I do? How much does cold really affect it? I was going to go lay some bags of ice on it for an hour or so--see if that helps
HELP!!!
HELP!!!
Problem solved! Rears are on and fronts are getting mounted in like 15 minutes. How did I get the stuck wheel off? One Word: BFH
I'll get pics up asap. Here's where they'll be:
www.cardomain.com/id/black6SpdTA
Originally posted by Zack
my afs wheels took some pounding by me to get them to seat against the hub. The use of the impact gun help to insure to sat
Definately a big improvement.
Now go show the Mach a thing or two.
-Corey
Apr 3, 2015 10:54 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
