Would this wheel fit my 95z?
Re: Would this wheel fit my 95z?
I don't see any with the 4th Gen bolt pattern (120.65mm), although some people have used the 120mm BMW bolt pattern. I wouldn't, but some people have. Then, they don't appear to have anything more than a 38mm offset, and not anything even close to that in a 9.5" width. Which specific wheel size are you looking at.... most of the wheels on that page won't fit, but maybe you have a specific width/offset in mind?
What rubs is determined by the "offset", the outside diameter of the tire, and the width of the tire.... for a 9.5" wheel on a 4th Gen, you need an offset in the range of 40-56mm. A 40mm offset will put the outer edge of the front wheel/tire just at the very edge of the fender, maybe a shade outside. A 56mm offset will move it in about 5/8" from the edge of the fender.
StangKilla has some 19" adr's on his car. They look good. Maybe he will chime in with what offset and stuff, or do a search and you will probably find it.
Magenta_Hearts
Mar 29, 2017 08:54 PM
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
