will c5 rims fit my 95 T.A
Old Jan 22, 2007 | 05:53 PM
diamondhill's Avatar
Question will c5 rims fit my 95 T.A
http://dallas.craigslist.org/pts/258101993.html will these rims fit my ride ? talked him down to 300
Old Jan 22, 2007 | 06:56 PM
68z28's Avatar
http://web.camaross.com/forums/showthread.php?t=312442
The sticky threads at the top are verrrrrry useful for this info. You should find what your looking for there.
Old Jan 22, 2007 | 09:58 PM
They are listed as "Factory" wheels, but those are not the OEM wheel sizes for the 97-99 C5 Corvette. The stock wheels were:
Rear: 18x9.5" 61mm offset
Front: 17x8.5" 56mm offset
With many late model F-Body and C5 wheels, you may find the hole in the rear wheels for the axle hub is too small, and needs to be enlarged slightly to fit over the hubs on the 93-96 F-Bodys.
How the wheels sit with regard to fitting under the fender, or rubbing the tire on the inside fender liner will depend on the actual offset of the wheels. If they are genuine GM OEM Corvette wheels, they will fit. But aftermarket "replica" wheels sometimes have different offsets.
LD Kirk
Apr 30, 2015 08:54 AM
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
