wheels and tires??
Old Jul 23, 2013 | 07:43 PM
rguzman's Avatar
wheels and tires??
What is the biggest tire i can fit in the rear on a 95 camaro width and side wall Rim size is 18X9.5 any advice is appreciated
Old Jul 24, 2013 | 02:40 PM
Re: wheels and tires??
Well.... this is the "Fuel and Ignition" forum. I'll move this thread to the "Wheels and Tires" forum.
Old Jul 24, 2013 | 02:45 PM
The widest tire you can put on a 9.5" wide wheel is typically a 285/35-18 (26.1" outside diameter).
Whether that tire will rub on anything will be determined by the offset of the wheel. If you are in the range of 40 - 56mm offset, you shouldn't have any problems. The 40mm offset will put the outside edge of the wheel/tire near the outside edge of the fender. The 56mm offset will move the outside edge of the wheel/tire deeper into the wheel well.
Old Jul 24, 2013 | 06:32 PM
rguzman's Avatar
thankyou sorry for putting question in wrong section
Old Sep 12, 2013 | 08:54 PM
rhettjstone's Avatar
What kind of tires are you thinking about going with?
I got a set of Michelin Pilot MXM4s awhile back (Michelin Pilot MXM4 Tires at SimpleTire.com) and could not be happier with them. Great ride, handling, stable, excellent road manners.
Old Sep 12, 2013 | 09:24 PM
Mr99SS's Avatar
The Michelin pilot sport 2 are awesome !
carguy0119
Apr 11, 2016 11:11 PM
dpw21562
Jan 23, 2015 04:58 PM
hotrodyou1
Dec 20, 2014 10:05 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
