what size drag radial
Old Apr 11, 2006 | 12:43 PM
350lsi's Avatar
Cool what size drag radial
i have a 98 z28 with draglites 15x3 on front and 15x8 in rear with a 275/60r15
mt et streets the rear tires rub on inner fenderwell what other tire size option do i have i also think tires look to big for rear any pics would help
Old Apr 11, 2006 | 04:14 PM
Re: what size drag radial
What's the backspace on the 15x8" Draglite? Typically you would use a 5.5" BS, and that should leave the inner edge of the tire about 1.5-2" from the inner fender liner. Where is the tire rubbing..... sidewall or tread? The fact that its a 28" tire isn't helping. Do you need a 28" tire, or could you work with a 26" or 27" tire?
Old Apr 12, 2006 | 07:50 PM
350lsi's Avatar
Cool Re: what size drag radial
im not sure what the backspacing is but i had to grind on caliper for them to fit
they rub on the very top of the sidewall i don't have to have a 28'' tire but i don't know how a 26 0r 27'' tire would look or what size that would come out to
if you know that a 26 or 27 tire would look good let me know
Old Apr 16, 2006 | 06:35 PM
shady93z's Avatar
the sidewall is probably rubbing the inner wheel well right above the lower control arm. it can be fixed with a hammer. doesnt take much, just a few whacks that no one will ever see.
Old Apr 17, 2006 | 08:23 AM
Grinding the caliper fins has nothing to do with the backspace.... the interference with the caliper fins is on the center disc.
If you get a wheel with the correct backspace, it should not rub. I have a 15x10" wheel with a 7.5" BS, and 28x11.5-15 QTP's and all it took was a bit of hammering on the inner fender liners. With a 5.5" BS 15x8" wheel, you would have 2" more clearance from the inside edge of the wheel to the inner fender liner than I have.
It doesn't sound like the problem is the tire diameter. Sounds like you have too much backspace.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
94Form
Jul 17, 2015 10:56 PM
mrwz28
Jul 8, 2015 09:11 PM
