Trans am wheels
Old Mar 8, 2016 | 05:04 PM
Ryley Archer's Avatar
Trans am wheels
Hey there! I have a 1994 t/a with after market 17" rims I'm wanting new tires and wanted to know what would be the widest and tallest I could go? Or any suggestion I have 275/40zR17 on right now and wanting a bit wider maybe a little taller
Old Mar 8, 2016 | 10:57 PM
Re: Trans am wheels
If by "taller" you mean a larger outside diameter you will need to reprogram the PCM for the new tire diameter, or else your speedometer will read lower than actual speed.
How wide you can go on the tires depends on the width of the wheels. What is the width? 285/40-17's are getting harder to find. 315/35-17 would match your current diameter, are getting harder to find, and typically require at least a 10" wide wheel.
jim9
Aug 27, 2022 10:40 PM
LowRyter
Apr 28, 2016 05:37 PM
UKNOWME
Mar 19, 2016 08:01 PM
IDriveA95Z28
Feb 29, 2016 10:41 PM
95LT4Z28
Wheels and Tires
Feb 21, 2016 10:03 PM
