traction control problems 17s in the front 18s in back
Old Mar 25, 2006 | 12:49 AM
teal99camarov6's Avatar
Ive got some 17 inch c5 rims in the front and 18s in the back. My traction control kicks in at 60 like the car has no traction. I have to turn off the ASR in order for the gas pedal to work also, when I break hard the ABS brakes kick in. How do I fix this, I've got HPTuners and the speedo is set for the rear 18s.
Old Mar 25, 2006 | 08:34 PM
lastZ's Avatar
Re: traction control problems 17s in the front 18s in back
what are your tires like? i have the same set up as you and i do not have that problem.....im at a loss...anyone else?
Old Mar 26, 2006 | 07:39 AM
my setup is the way it came from GM on the vettes 245s in the front 275s in the back
Old Mar 26, 2006 | 10:02 AM
What is the full tire size spec (including aspect ratio)? With a 245/45-17 in the front and a 275/40-18 in the back you would have a diameter difference of about 1".
Old Mar 26, 2006 | 04:58 PM
what does this mean? The difference of one inch, should I adjust the tire size to be between those two sizes?
Old Mar 28, 2006 | 09:16 AM
That shouldn't cause problems with the traction control, but it might. Borrow a pair of stock diameter tires for the back and see if the problem goes away.
Are your tire sizes exactly the ones I assumed?
Old Mar 29, 2006 | 04:55 PM
you guessed correctly. My car's ABS comes on even when the the car isnt slipping and once the car hts 60 the ASR comes on unless i have it turned off Help Please! I have HPTuners and I programed the new tire size for the rear tires, but should I calculate it to an average of the front and rear tires to prevent this problem from happening again?
Old Mar 30, 2006 | 09:21 AM
Sounds like you may have a wheel sensor problem. The easiest way to rule out the discrepancy in front and rear tire sizes would be to try a set of stock diameter tires on the back. If the problem is still there, its not related to tire size.
I can't imagine why they would make the ABS and TCS sensitive to a 1" difference in tire diameter.... you can get differences that large when you mix and match brands in the same size, allow for new tread vs. bald, and allow for over- and under-inflation.
Have you ever had a "scan" done on the ABS/TCS computer?
Old Mar 30, 2006 | 09:58 AM
Can I do the Scan with HPTuners? I dont think I have, but the car naver had this problem until I put the C5 wheels on and programing for the new diamater didnt help at all. I heard the TCS(ASR)/ABS system are separate and I cant program for them. Are new sensors epensive? Could I replace them just as a troubleshooting measure, or would that be too costly?
Old Apr 12, 2006 | 02:45 PM
can anyone help? This is getting annoying!
Old Apr 13, 2006 | 12:55 AM
eagleknight97's Avatar
Did you throw a set of stock size tires on there yet?
Old Apr 13, 2006 | 08:05 AM
We've been trying to help, but you seem to be ignoring our suggestions. Try swapping the tires. Get it scanned by a technician with a Tech-2 scanner. I doubt that you can do it with HP Tuners.
Old Apr 16, 2006 | 09:11 PM
Carpe Diem's Avatar
99's have 4 channel, right?(sensors at the end of the axle tubes?) I know when I was swapping rears I cleaned up a LOT of shaving that were on the sensors by the reluctor rings. Could that have anything to do with it??
Old Apr 17, 2006 | 08:17 AM
All years with TCS have the 4-channel system, with the reluctor wheels behind the axle hubs.
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
CLEAR
Aug 13, 2002 10:07 AM
