Is the sumitomo HTR + a good tire?
Old Jan 8, 2008 | 01:36 PM
  #16
kendall5000's Avatar
Ok...sorry and thanks. The tire is Yokohama avs es 100
Old Jan 8, 2008 | 09:43 PM
  #17
switch's Avatar
Originally Posted by Greed4Speed
You're comparing an all season Sumi to a Summer only Kumho? As much as I don't like them, the Kumho 712 will have better performance except in snow. You can't tell me a 400 AA A tire is going to out perform a 280 AA A tire in dry conditions which is when us sane people push our cars to the limits. The 712 even scored higher in Hydroplane resistance and wet traction.
I've had both the sumitomo's and the Kumho 712's. It's night and day. The Kumho's are relatively worthless IMO. Horrible dry traction and wet traction is an oxymoron; there is none. I'm not even trying to quote specs. This is what I've experienced.
I admitt that I have a realatively narrow spectrum of experience w/ alot of the tires mentioned above. I'm sure that there is a lot more out there that are great deals. There are just so many variables that you have to take into account when buying a tire. Don't make a snap judgment just because it worked for someone else. Use what everyone has experienced, and make a desicion based on what you now know and what your needs are.
Old Jan 9, 2008 | 01:59 PM
  #18
Greed4Speed's Avatar
Did you have the HTR+ , HTRZ or HTRZ II?
Old Jan 9, 2008 | 02:04 PM
  #19
Originally Posted by JakeRobb
Treadwear ratings are not regulated or standardized. Kumho's 280 AA A has absolutely nothing to do with Sumitomo's 400 AA A. You simply can't compare them and expect your conclusion to be accurate. The numbers are only good for comparing tires of the same brand, and even then, the exact meaning of the numbers and the scale to which they apply is unclear.
I know the ratings aren't regulated, but its been my experience that with that amount of difference in the spread there is a noticable difference in tread wear and traction even between different manufacturers.
Had this been comparing a 280 vs 320, I could see the 300-320 from a different manufacturer providing better traction than the Kumho @ 280, but for a tire rated at 400? No. Especially when you are comparing a tire that is considered summer only to an all season. All seasons don't run the softer rubber because the softer rubber doesn't do so well in the cold.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
