rims info and pics for 99 ta
Old Oct 8, 2007 | 03:16 PM
raw122's Avatar
ok im looking for wheels for my 99 TA and i might lower it a little,but i would like to know what size rims i should go with and tires ,i would like all thems to be the same size and offset to be the same,from what i seen 17's seams to be a good fit,so can any one post pics and or info
thanks for any help
Old Oct 8, 2007 | 04:23 PM
You've got to narrow it down a bit.... just about everyone moves to something larger than the stock 16x8" wheels. But you have to choose something between 17" and 20". Then there's the width.... anything from 8" - 11" wide will fit. Then its a matter of selecting the correct offset.... but you can't do that until you pick a width. And once you've narrowed down the wheel diameter and width, you can selct a tire size based on matching the stock tire diameter.
Have you looked through the FAQ stickied at the top of the Wheels and Tires forum topic page?
http://camaross.com/forums/showthread.php?t=312442
What size wheels do you think you want?
Here's a T/A with 17x9.5 front / 17x11.0 rear - is that similar to what you are looking for?:
Brent Franker also has an "Appearance" section on his website, with hundreds of different wheel photos:
http://www.bfranker.badz28.com/appearance/
Old Oct 8, 2007 | 06:21 PM
raw122's Avatar
i read that thread it helped some,yes the rims on that car is type that i like,but i have a few ?'s
1-i would like to have the front and rear the same offset can i do that and the wheels going to stick out on the car the same distance,i just want it to look like fit fits under the car right not sticking out to far and not stuck up under there like the oem ones do
2-the size i would like to stay at 17 or 18 price might make that choice for me
3-width would will depends on how wide i can go with out rubbing on the front or the rear and stick with the same offset and width on front and rear
Old Oct 9, 2007 | 01:43 PM
Look at the post in the FAQ regarding offset vs. width. It tells you what offset will put the wheel/tire at the fender edge, what offset will put it where the factory wheels sit, and what offset will cause the backspace to interfere with the body/suspension on the inside edge.
http://camaross.com/forums/showpost....4&postcount=17
canbaufo
May 17, 2015 10:35 AM
R@mpage
Apr 20, 2015 10:02 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
