replacing front calipers on 67 camaro
Old Apr 17, 2018 | 09:53 AM
gator66's Avatar
I replaced the bearing on the front of my 67 camaro. When putting the pads and calipers back on, I encountered a problem. The calipers will slide on over the rotor but the holes wont line up to put the bolts back in. Looks like they are lining up ok but are off
Old Apr 17, 2018 | 11:44 AM
ray42's Avatar
Re: replacing front calipers on 67 camaro
gator66,
Can you install the caliper bolts if the brake pads are removed? If so, then install the easy brake pad first, then the other one (which may take some fiddlin').
SiDeWaYZz28
Jul 18, 2007 03:27 PM
Blue89Bird
12
Sep 24, 2006 06:03 AM
ta4me
Mar 27, 2003 09:51 PM
Ken S
Dec 9, 2002 12:23 PM
