Race stars
Old Apr 20, 2014 | 12:31 PM
Indynut's Avatar
Race stars
Well this project has taken a little while to get together but here's the new Race Stars installed.
This forum was great for helping me figure out what I wanted for wheels so here's what I learned in here, then ordered, and then installed.
Front wheels are Race Star Industries- Drag Star’s 15X5” - 5X4.75 (2.375" BS) Summit Part Number: RCE-92-550244DP with BF Goodrich T/A’s size 215-70R-15’s
Rear wheels are Race Star’s Industries- Drag Star’s 15X8” - 5X4.75 (5.25” BS) Summit Part Number: RCE-92-580250DP with BF Goodrich T/A’s size 275-60R-15’s
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Apr 20, 2014 | 01:26 PM
Re: Race stars
Interesting. I haven't seen those wheels before. Do they clear the stock disc brakes without spacers or grinding the calipers?
What kind of power are you putting down that requires 28" tires in the rear? Have you corrected the tire diameter in the PCM? Have you gone to higher numerical rear gears to compensate for the larger diameter.
Old Apr 20, 2014 | 04:07 PM
Indynut's Avatar
Re: Race stars
No spacers required. No grinding required. Stock wheel studs.
Old May 16, 2014 | 03:05 PM
onebadponcho's Avatar
Re: Race stars
Seconded on the no spacers or grinding required, and I run 98-02 front brakes. You might want to change out those wheels studs though, as those wheels are NOT hubcentric (unless you get the hubcentric rings). Even then, with the shank style lug nuts the wheels use, they're nowhere close to being long enough to be considered NHRA legal and you will fail tech at the racetrack.
My parts lists is as follows:
Wheel Studs: Moroso 46245; Press-In, 12mm x 1.5 in. x 3.250 in. Long, .509 in. Diameter Knurl
http://www.summitracing.com/parts/mor-46245
Lug Nuts: McGard 63002; Shank with Washer, 12mm x 1.50 RH, Open End, Chrome Plated Steel
http://www.summitracing.com/parts/mcg-63002
Front Wheels: RaceStar RS92-550244 DP (15x5, 2.375" BS)
http://www.summitracing.com/parts/rce-92-550244dp
Front Tires: Cooper CS5 Ultra Touring 185/65R15 88H
Rear Wheels: RaceStar RS92-510254 DP (15x10, 7.25" BS)
http://www.summitracing.com/parts/rce-92-510254dp
Rear Tires: Mickey Thompson ET Drag Slicks 3053S 26x10-15
http://www.summitracing.com/parts/mtt-3053s
Old May 16, 2014 | 07:17 PM
itsyellow's Avatar
Re: Race stars
Love the wheels. They look really good.
karpetcm
Aug 14, 2015 03:02 PM
Louey
Pacific
Aug 7, 2015 01:47 AM
Boss002
Jul 24, 2015 10:47 AM
NewsBot
Jul 8, 2015 06:47 PM
