Race stars
Well this project has taken a little while to get together but here's the new Race Stars installed.
This forum was great for helping me figure out what I wanted for wheels so here's what I learned in here, then ordered, and then installed. Front wheels are Race Star Industries- Drag Star’s 15X5” - 5X4.75 (2.375" BS) Summit Part Number: RCE-92-550244DP with BF Goodrich T/A’s size 215-70R-15’s Rear wheels are Race Star’s Industries- Drag Star’s 15X8” - 5X4.75 (5.25” BS) Summit Part Number: RCE-92-580250DP with BF Goodrich T/A’s size 275-60R-15’s [IMG]http://img.photobucket.com/albums/v2...psda1f3c1b.jpg[/IMG] [IMG]http://img.photobucket.com/albums/v2...psb1546f40.jpg[/IMG] [IMG]http://img.photobucket.com/albums/v2...psc95ece74.jpg[/IMG] [IMG]http://img.photobucket.com/albums/v2...ps6e0ee8a8.jpg[/IMG] |
Re: Race stars
Interesting. I haven't seen those wheels before. Do they clear the stock disc brakes without spacers or grinding the calipers?
What kind of power are you putting down that requires 28" tires in the rear? Have you corrected the tire diameter in the PCM? Have you gone to higher numerical rear gears to compensate for the larger diameter. |
Re: Race stars
Originally Posted by Injuneer
(Post 6961363)
Re: Race stars
Originally Posted by Indynut
(Post 6961366)
No spacers required. No grinding required. Stock wheel studs. My parts lists is as follows: Wheel Studs: Moroso 46245; Press-In, 12mm x 1.5 in. x 3.250 in. Long, .509 in. Diameter Knurl http://www.summitracing.com/parts/mor-46245 Lug Nuts: McGard 63002; Shank with Washer, 12mm x 1.50 RH, Open End, Chrome Plated Steel http://www.summitracing.com/parts/mcg-63002 Front Wheels: RaceStar RS92-550244 DP (15x5, 2.375" BS) http://www.summitracing.com/parts/rce-92-550244dp Front Tires: Cooper CS5 Ultra Touring 185/65R15 88H Rear Wheels: RaceStar RS92-510254 DP (15x10, 7.25" BS) http://www.summitracing.com/parts/rce-92-510254dp Rear Tires: Mickey Thompson ET Drag Slicks 3053S 26x10-15 http://www.summitracing.com/parts/mtt-3053s |
Re: Race stars
Love the wheels. They look really good.
