Question / Advice on Rim size
Old Jul 31, 2011 | 01:51 PM
Larsv8's Avatar
I've decided I would like to go with the chrome TTM rim, but there is a ton of sizing options.
My application is a 95 Z28 with stock height and 275/40/17 tires.
I read through the FAQ and it seems like this:
http://www.wheelsforless.com/detail.aspx?ID=1432
might be the best choice.
Would a different offset/backspace combo look better perhaps?
Thanks!
Old Jul 31, 2011 | 05:04 PM
Re: Question / Advice on Rim size
17" x 9.0" 45mm offset works fine. If you look at a stock WS6 or an SS coupe, with the factory 17" x 9.0" 50mm offset wheels, these will be moved outwards about 1/5th of an inch compared to the factory wheels. In general, moving the wheels toward the outside of the car looks better, but that's based on personal preference.
You could also consider using the 17" x 9.0" in the front, and 17 x 10.5" 44mm in the back, and 315/35-17 tires.
Old Jul 31, 2011 | 07:15 PM
Larsv8's Avatar
Thanks for the info. I have 4 new tires, so I was going to go all the same currently, although I may try the staggered in the future.
What offset creates flushness with the wheel well?
Old Jul 31, 2011 | 11:11 PM
Look at the post in the FAQ that provides guidelines on offset vs. width. In the 17x9.0" listing, there is a link to a post with pictures of a car REPORTEDLY with 25mm offset, putting the edge of the tire slightly outside of the front fender. The back probably wouldn't be outside the fender.
HectorM52
Jul 30, 2017 11:46 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
ChrisFrez
Feb 15, 2015 08:12 AM
Kato
Jan 26, 2015 09:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
