Question about ET drags?
Re: Question about ET drags?
Originally Posted by MTL_Z28
Beginning of this season I picked up a spec stage 3 clutch, Spohn HD driveshaft, and moser 12-bolt (33 spline, heavy duty posi, Performance cover, etc..) because I knew I was going to run slicks at the track from now on.
ooops well i guess that you arn`t gonna damage that huh
i thought you were running the stock rear still, sorrry
My 7.5 has an auburn diff with yukon gears, totally new sea;s and bearings and has new Moser axle shafts. (my gear install a and rear end rebuild was under $400 to) guy that built it sad as long as i dont do anything radical to the engine/trans he will warranty it for a year, so if i blow it oh well. he builds drivetrains for super modified dirt track cars so I trust his work.
Im really glad injuneer mentioned that about tire pressure, i'm new to using a non-radial tire and the guy at goodyear that mounted them said not to let them run anywhere under 25psi
When I drive my car on the street with ET Drags, and knowing that I'm not going to be doing any racing, I run them at 24psi. But at the track, I'm down to about 12-13psi (with tubes). I've worked as crew on a 4th Gen that was pulling 1.30 60-fts (8.60@160+MPH) and he ran between 10-12psi.
Moshbmx1
Jan 20, 2015 03:27 PM
Camaro90RS
Jul 23, 2002 07:57 AM
