Prostar 3.5 what tire ?
Old Mar 7, 2011 | 04:46 PM
WhiteCamaro88's Avatar
Have prostars that need tires . 15x3.5 rims . Currently have 165/80r15's on them . Mikeys sportsmans list them in inches they rec. 24X5R15in. tires or 26x6r15in. tire is the 26x6 tire to big to run on a 3.5rim ? i would like to . Whats the biggest tire you guys running on the 3.5 rim ?
any info is apprec.
Old Mar 7, 2011 | 11:09 PM
Re: Prostar 3.5 what tire ?
My 3.5" Pro-Star has "DRAG RACE ONLY" stamped right on the surface of the wheel. They are not designed for the high lateral loads encountered in street driving.
In any case, you need a 26" diameter front tire. 24" is way too small. And it has to have a load capacity that matches or exceeds the stock tire.
If by "Mikeys sportsmans" you mean the M/T Sportsman Front, they make a 26 x 7.5 - 15 that fits on a wheel 3.5" - 6" wide. That is a bias ply tire, and will not work very well with radials in the rear. Might produce some fairly dangerous handling
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Latronaxe
Jul 20, 2015 12:00 PM
Slayer
Jul 4, 2015 03:06 PM
