pics of 315/35s on 17x9.5 rims please
Old Feb 27, 2005 | 08:04 PM
  #16
joshp007's Avatar
Re: pics of 315/35s on 17x9.5 rims please
Again Zack we dont care about your opinion. I was asking for pics not for opinions. We like our cars to satisfy our taste not yours
Old Feb 27, 2005 | 08:59 PM
  #17
cc89formula's Avatar
Josh arent you from the amarillo area? theres a guy here in town Shaun with a blue '00 formula running rear 315's on a 17X11s and they look awesome
Old Feb 27, 2005 | 10:21 PM
  #18
fstenuf's Avatar
n2oblkz: i noticed you said that they don't rub? how do they not rub? but the tires will rub on a 17X11 rim?
i think your car is tight as night just my .02
Old Feb 27, 2005 | 10:24 PM
  #19
Zack's Avatar
well coming from a guy that sells and installs tires for a living, my opinion on what fits should be one taken into consideration....
Old Feb 27, 2005 | 10:59 PM
  #20
n2oblkz
Guest
Posts: n/a
Posted by: fstenuf
Thanks for the comments. I don't know why they dont' rub. I have got really good clearance inside the wheel well and they are just about flush on the outside, maybe in just a little. I think that it may be the offset on these rims, it is 44mm. I also have jounce bumper spacers installed and I know that a lot of people say that they are useless but I know that I removed them once and with my car lowered about 1.5" in the back, they would rub under hard acceleration without the jounce bumper spacers installed.
Posted by: Zack
I know that I was a little concerned about it before I purchased the rims and tires so before I bought anything, I called and spoke with the tech departments at Enkei and at Sumitomo. Both of the tech's said that they recommend the 315 to be used with a minimum of a 10.5" wide rim but that using that size of a tire on a 9.5" rim would not cause ANY problems as long as proper tire inflation is used and that the only issue could possibly be un-even tire wear if the tires are not inflated properly. As of yet, I have not had that issue. Actually the tech at Enkei said that he has seen it done many times without problems. So, I feel safe in doing it for my purposes and don't anticipate any issues.
Old Feb 27, 2005 | 11:02 PM
  #21
Welllllll...... first the narrower width of the wheel puts it further from the inner fender and the fender lip. Second, the narrower rim reduces the section width of the tire. For example, a tire that measures at 12.4" section width on an 11" rim will lose about 0.75" section wdith when mounted on a 9.5" wide wheel. Wheel is narrower + tire is narrower = no rubbing.
Old Mar 3, 2005 | 08:17 PM
  #22
joshp007's Avatar
cc89formula yes I live about an hour from amarillo. Guys I just wanted pics of guys that are running this combo. I didnt want comments. My car and I can do it my way. If you dont want em on your car then dont put em on ok. Hey n20blkz thanks for all your help man! Your pics helped me out a lot. I am getting my 315s on tomorrow and I will shoot you some pics.
Old Mar 3, 2005 | 09:00 PM
  #23
n2oblkz
Guest
Posts: n/a
Hey good luck with them and I hope that they work out for you!
Old Mar 6, 2005 | 06:58 PM
  #24
joshp007's Avatar
These tires have a great contact patch to the ground. All the tread makes great contact and they fit very well. They grip the road very very well also. Zack im not trying to be a butthole its just this is my car and I just wanted some pics of what it would look like. I have some pics on my cardomain site if anyone wants to check them out. Thanks for all your guys help!! http://www.cardomain.com/memberpage/716929
Old Mar 6, 2005 | 07:29 PM
  #25
n2oblkz
Guest
Posts: n/a
Hey. those look great, they don't buldge much at all. I'm glad that they worked out for you.
Old Mar 6, 2005 | 07:32 PM
  #26
joshp007's Avatar
Thanks man. Yeah I thought they would bulge way more than that. They make complete contact with the ground also. My tire guy said if I run it 32-33psi they should wear even also. Again thanks for your help and replies n2oblkz!!
Old Mar 6, 2005 | 11:01 PM
  #27
n2oblkz
Guest
Posts: n/a
Thats about where I keep my tire pressure also, again, no problems.
Old Mar 22, 2005 | 05:35 PM
  #28
TheBlur's Avatar
More pics, less chit chat...I want a pic from behind. Anybody got one ? Maybe with ZR1's ?
They look bad ***, lick the head....nuff said
Old Mar 22, 2005 | 06:15 PM
  #29
n2oblkz
Guest
Posts: n/a
Here is one of mine from behind. It's not a very good one, but I will check and see if I have any better ones.
[img=http://img212.exs.cx/img212/6496/plate2xo.th.jpg]
Old Mar 22, 2005 | 06:18 PM
  #30
n2oblkz
Guest
Posts: n/a
Here is another.
[img=http://img212.exs.cx/img212/4861/picture1447ah.th.jpg]
