Offset and spacer ?
Old May 16, 2006 | 10:13 PM
madtek's Avatar
Offset and spacer ?
I tried the search, but I couldnt find anything exact. Basically will a 17x11" rim with a 68.5 offset fit on the rear of a 1997 Camaro? If so what size spacer do I need? Im ready to buy these rims, but want to make sure they will work. Any help is appreciated.
Old May 16, 2006 | 11:51 PM
eagleknight97's Avatar
Re: Offset and spacer ?
Cant give you the specifics, but im assuming that you are saying the 17x11 rim has a +68.5mm offset? If so, then yes, it should fit, but youll need a decent sized spacer and a BFH.
Old May 17, 2006 | 07:59 AM
That's an 8.66" backspace, meaning its sitting in almost 3/4" farther than the correct 50mm offset wheels. You would need an 18.5mm (0.73") spacer - and not a "sandwich" type. A bolt-on spacer.
Where did you find a 68.5mm offset 17x11 ZR1 wheel? I've seen 36.5mm and 50mm, but never a 68.5mm offset.
Old May 17, 2006 | 09:21 AM
madtek's Avatar
Thanks for all the help guys. Its actually a Fikse FM5 which he said was the correct offset for a C5. Its a good price, but do you think it should be done?
Old May 17, 2006 | 05:58 PM
If a real C4 Grand Sport uses a 50mm offset (7.93" BS) - and these wheels are used routinely on a 4th Gen F-Body, its hard to understand why you are buying wheels that fit a C5, and then having to spend another big chunk of $$$$$$ to get high quality spacers and all the headaches that go with them.
But if they are used, and they are cheap, maybe it makes sense.
Old May 17, 2006 | 07:04 PM
madtek's Avatar
Your right. Probably not worth it. Thanks for the help, Ill let these wheels slide.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
detroitmuscle
Jul 31, 2015 04:21 AM
BLK1997Z28
May 2, 2015 01:26 PM
