Which Offset?
Old May 1, 2007 | 10:53 PM
Black_Z28's Avatar
Which Offset?
I'm looking at a set of wheels that are 18x9.5". I'm thinking a offset of +40 would work, and put the wheel almost directly below the fenders. Is this correct? Or would a offset of +50 work better? I will be running these wheels on all four corners, and I will most likely run a 275/35/18 tire.
Thanks.
Old May 2, 2007 | 10:14 AM
http://camaross.com/forums/showpost....4&postcount=17
Old May 2, 2007 | 06:23 PM
Black_Z28's Avatar
Thanks, I saw that. But I guess I was just wondering if anyone had first hand experience or pictures of 18x9.5" wheels in 40 and 50 offsets.
Old May 2, 2007 | 06:48 PM
The diameter of the wheel doesn't affect the side-to-side spacing. A picture of an 18x9.5" wide wheel with a 45mm offset is going to put the outer edge of the tire in the same place as a 17x9.5" 45mm offset wheel.
Old May 4, 2007 | 09:35 AM
wayfastwhitey's Avatar
Mine have a 45mm offset I think and they are just right IMO. Although I think 40 would be a safe move. Some bad pics, but it might give you an idea.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
blksunshine
Oct 14, 2002 01:01 PM
red95bird
Oct 10, 2002 12:36 AM
