Which Offset?
Which Offset?
I'm looking at a set of wheels that are 18x9.5". I'm thinking a offset of +40 would work, and put the wheel almost directly below the fenders. Is this correct? Or would a offset of +50 work better? I will be running these wheels on all four corners, and I will most likely run a 275/35/18 tire.
Thanks.
Thanks.
The diameter of the wheel doesn't affect the side-to-side spacing. A picture of an 18x9.5" wide wheel with a 45mm offset is going to put the outer edge of the tire in the same place as a 17x9.5" 45mm offset wheel.
Henson071
Dec 30, 2015 09:55 PM
blksunshine
Oct 14, 2002 01:01 PM
