nitto sizes
Old Jun 6, 2005 | 12:36 PM
DiabloGT's Avatar
nitto sizes
well my riveted chrome z06 rims are coming in this week so hopefully by next month i can afford new tires, i want nitto ones; the rims are 17"x9.5" in front and 18"x10.5" in rear, will the 305/35ZR-18 101Y B size fit my rear rims? and whats the best/widest i should put on the front ones?
thanks
Old Jun 6, 2005 | 03:13 PM
CamaroSS30thAnn's Avatar
Re: nitto sizes
295s for the front, and 315 drs for teh back , if u really want the 305 in the back im sure they would work
Old Jun 6, 2005 | 04:06 PM
DiabloGT's Avatar
Re: nitto sizes
but on tires.com they dont have 315's in rear for 18" rims only 305 is biggest, and i would wanna know liek what spec does it have to be in fornt like 295/40/17
thanks
Old Jun 6, 2005 | 04:58 PM
Re: nitto sizes
If you have 17" wheels in the front, you will want either a 275/40-17 or a 285/40-17. They don't make a 295 in the 17's.
On the back, a 305/35-18 will be almost about 3/4" larger in diameter than the stock tires. That will throw your speedo off by about 3%, or a little less than 2mph error at 60mph.
Finally, what is the offset on the 18x10.5" wheels? If the offset is too large, you may have problems with the inside edge of the tires rubbing on the inner fender liners.
Old Jun 6, 2005 | 06:01 PM
Re: nitto sizes
ah thanks injuneer i didnt realize his fronst were 17s
Old Jun 7, 2005 | 05:39 PM
DiabloGT's Avatar
Re: nitto sizes
are there an nittos that are 305's or 315's that wont throw off the speedo? and would it make it 2mph less or more? and what is my total mph rating is my fronts are V and my rear are Z?
thanks
EDIT: is it physically impossible to put a 315/35R-17 102V tire on the 18" rim since its for 17" instead?
thanks
Old Jun 8, 2005 | 12:29 AM
Re: nitto sizes
Your car is limited by the lowest speed rated tire, and the "V" is good for 149MPH.
You MUST use only an 18" tire on an 18" wheel. You can not put a 17" tire on an 18" wheel - physically impossible.
As far as the speedometer error....
1. What size tires came on your car stock? They were either 235/55-16 or 245/50-16?
2. The "error" can be corrected by adjusting the tire diameter in the PCM.
Old Jun 8, 2005 | 09:43 AM
DiabloGT's Avatar
Re: nitto sizes
the stock was 245, and do u think madz28's pcm thing can fix it?
thanks
Old Jun 8, 2005 | 12:12 PM
Re: nitto sizes
Yes, anyone with the correct software, or a Hypertech Power Programmer can correct for tire diameter.
Old Jun 8, 2005 | 02:33 PM
DiabloGT's Avatar
Re: nitto sizes
and i heard you had a description of where exactly to hit in the rear wheel well for it to not rub?
thanks
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
