how to on shaving bumpstops for 17x11 clearance?
Old Jul 26, 2006 | 10:02 PM
RichJ's Avatar
What is the best way to trim the bumpstops like this?
Do you unbolt the rubber bumper first? Then cut down the bracket to the bolt holes? What's the best tool -- cutoff wheel? sawzall? Then what is the best way to cut the rubber bumper? Do you bolt it back on and then cut it? Any suggestions for cutting the rubber?
Just looking for baby step instructions on how best to do this.
Thanks!
Old Jul 26, 2006 | 11:38 PM
Re: how to on shaving bumpstops for 17x11 clearance?
I did that so long ago I can't even remember. I didn't remove the bump stop from the bracket, and I used an air powered die grinder. I think I used a stone, but may have used a cut-off wheel at some point.
Don't worry about the "rubber".... its actually a fairly fragile white material that will probably crumble and fall apart. It was still in fairly decent shape in 2000 when I did that, but with yours being 11 years old, they may just fall apart.
Old Jul 27, 2006 | 12:39 AM
Dave '97 Z28 M6's Avatar
Yeah, mine fell apart (I used a grinder on them). The rubber-type material separated from the metal base. So I bought new ones and "modified" them... they weren't too much money. PN is 10164173, in case you need it RichJ.
Old Jul 27, 2006 | 08:08 AM
davidz28guy's Avatar
mine are pretty much gone, never got around to getting new ones, i dont think its effected anything as of yet, but id still like to get some new ones eventually
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
realistyc
Jul 28, 2015 07:32 PM
