how much faster can wheels make me?
Old Feb 1, 2008 | 11:22 PM
sn8ke eatr's Avatar
well im curretly running a high 11 on my cam only lt1 and am looking to go faster by dropping weight.
right now im running on 97-99 chrome z28 rims with a bfg 255 dr out back.i know these are very heavy wheels. my question is how much faster do you think i could expect by switching to a drag wheel tire combo ( ie. pro star or something similar). id like to run a 3.5 inch wheel up front with a 10" out back with maybe 275 drag radials. is it worth the money to get the wheels or should i use the money elsewhere to drop weight.
any input would be cool guys,
btw mods if this is in the wrong thread sorry, i wasent sure where to put it.
Old Feb 2, 2008 | 07:10 AM
The Engineer's Avatar
Wheels and tires are rotating mass, so the weight savings multiplies by a factor of three (I think that is correct).
My factory wheels and tire were almost 50 pounds each. With the skinny fronts you can save about 30 pounds per wheel/tire (60 total front x 3 = 180) and on the rears about 15 pounds per wheel/tire (30 total rear x 3 = 90).
So, you’re looking at about 270 pounds theoretical rotating mass reduction in weight and that “could be” over two tenths (maybe 0.27) quicker ET.
WD
Old Feb 3, 2008 | 02:23 AM
sn8ke eatr's Avatar
hmm.. thats alot. thanks for the reply man. i think i may run skinnies up front for the track.
Old Feb 4, 2008 | 04:23 PM
30AnniversaryZ28's Avatar
The stock wheels really weigh that much? I didn't think they were that heavy.
Old Feb 4, 2008 | 09:18 PM
Look at the 5th post in the Wheels and Tires FAQ, stickied at the top of the Wheels and Tires forum topic page, for weights of various wheel/tire combos. Stock 16x8 wheel/tire combos seem to range from 45-50#.
Old Feb 5, 2008 | 11:53 PM
slomarao's Avatar
plus you ll cut much better 60fts on 15's than 16's. The extra sidewall will help. Overall I think you will run 3/10's quicker, maybe 4/10's. That will depend on your short times again.
Old Feb 6, 2008 | 01:57 AM
red_94z's Avatar
droped my lt1 a/b .15 with just skinnies on front... there like the ones u want
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
ro2207
Dec 4, 2014 06:18 PM
ChrisFrez
Nov 30, 2014 08:41 AM
