How do you get a set of 15in slicks n skinnes to fit a 94 Camaro???
Just wanted to know how to fit a set of slicks and skinnies. I tried to mount the fronts and the wheel was to tight of a fit, maybe cause the F Body was designed for 16in rims. I herd of grinding down calipers? How could I do that? What tools would I use? Does it ruin the calipers? Any helpful information will be appreciated. Thank You ~ hozb 817
Re: How do you get a set of 15in slicks n skinnes to fit a 94 Camaro???
I have experience with the Weld Pro-Stars.
Front:
You need a 5/16" spacer to clear the spring clips that hold the pads in the calipers, and the big horizontal arms that the calipers rest on. Also requires longer studs to meet NHRA tech.
Rear:
Grind the fins off the caliper. Doesn't hurt them. See picture.
http://cjcfo.fbody.com/members/injun.../DCP04016a.jpg
Front:
Rear:
NewsBot
Dec 30, 2014 09:40 AM
NewsBot
Dec 21, 2014 06:55 PM
Dec 4, 2014 11:56 AM
