Help telstar catching brake clips
Old Feb 14, 2008 | 04:04 PM
93DGTA's Avatar
Front brakes are the stock 93 trans am got front telstars There 15x4 1-5/8 RS. Problem is the clips that hold the brake pads the edge is catching the wheel in the back.. Im sure theres a cure . any tips or input would be a great help Thanks
Old Feb 14, 2008 | 04:10 PM
Same thing you do with a Weld Pro-Star in the front..... add a 5/16" spacer. And if the studs are then too short, replace with longer studs. Read the FAQ on racing wheels, "stickied" at the top of the "Wheels and Tires" forum topic listing. Specifically, the one about the Pro-Stars.
Seems like this doesn't usually happen with the Telstars, though.
Old Feb 14, 2008 | 04:28 PM
93DGTA's Avatar
Just the very edge is catching.These telstars were made in 2006 got them from summit. Thanks for the reply
RX Speed Works
Aug 11, 2015 11:16 PM
whitehooptie
Jul 12, 2015 06:10 PM
NewsBot
Jul 8, 2015 06:47 PM
