help ! offset ?
Old Jul 17, 2009 | 02:37 PM
chuckys95's Avatar
help ! offset ?
i have looked in FAQ section and still haven't figured this out yet.
trying to find out if these will fit on a 95 Z28 front and rear.
19X10 with 65mm offset
Old Jul 17, 2009 | 04:55 PM
That's an 8.0" backspace. In the back, its likely to put the inside edge of the tire against the high points of the inner fender.... same as the problems described in the FAQ for the 17x11 50mm wheels. Except maybe slightly worse, since its about 1/10th" more backspace.
In the front, its hadr to call. With a 17" wheel, the max backspace is about 7.4". Whether the steering knuckle curves backward far enough to clear a 19" wheel is unclear. Would problably need spacers, like the people use who run the 17x11 50mm wheels on the front.
This post in the FAQ summarizes offset vs. width. Its a rough guide, but indicates what I described above.
https://www.camaroz28.com/forums/sho...4&postcount=15
Old Jul 19, 2009 | 12:57 PM
bluz28's Avatar
If you run them with a 20mm hub spacer(I know H&R makes them) you'll effectly have a +45 offset, which should fit with no problems. Or you could go with a 1" hub spacer which would push the wheels out about a 1/4" further, with a offset around +40 you might need to roll the fender lips.
Old Jul 19, 2009 | 02:03 PM
chuckys95's Avatar
i did have some 19x10 CCW SP505a's on it at one time, they were a 58 or 59mm offset. and i didn't use any spacers.
i am just unsure of that same width wheel with 6-7mm more offset.
here are a couple pics with the 19x10 CCWs with a 58mm offset.
Old Aug 4, 2009 | 01:48 PM
bluz28's Avatar
6-7mm is .236" to .276", so about 1/4" more.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
blksunshine
Oct 14, 2002 01:01 PM
red95bird
Oct 10, 2002 12:36 AM
