Draglite help
Draglite help
I am sure its been asked, but what backspacing and bolt circle size do I need for draglites. 15x4's and 15x10's. and what size tires? I dont drive it on the street everyday.
Re: Draglite help
The five lugnuts weld wheels come with dual bolt pattern 4.5" and 4.75, you'll use the 4.75" holes. I have 15x3.5 with 1.75" backspace, and 15x10 with 7.5" backspace. As for the tires, I have the moroso ds2 for the front and 11.5x15x26 et streets. I also used a 5/16" spacers to clear the front calipers, but still required very minimal grinding of the LS1 calipers. You have to use longer studs, I think the number for the 12mm 1.5 pitch is ARP 7708.
Re: Draglite help
Originally Posted by SWINGRRR
Thanks for the help. I have heard that 15x3.5's are killer on the street.
Is 2 1/4 BS right for a 15x4?
JoshGuitar
Jul 10, 2003 09:14 AM
