Chrome wheel leaking HELP!!!
Old May 16, 2007 | 05:32 PM
jfv04's Avatar
Question Chrome wheel leaking HELP!!!
I have a 2002 Z28 with the stock chrome rims. The front left wheel has had a slow leak since I bought it back in Dec. 04. I have had it fixed twice already at 2 different shops. The bead will hold for awhile and then it begins to leak again. I saw that the chrome is chipping off of the inside of the wheel where the bead is. I have heard that this is a common problem with chrome wheels. Is this a fixable problem? What should I do?
Old May 16, 2007 | 08:09 PM
gt_biker13's Avatar
Did they use bead sealer when they did it?
Old May 16, 2007 | 08:16 PM
jfv04's Avatar
Yeah. I believe that they wire brushed it and then sealed it up with bead sealant. It will not leak for like a couple of months then I find the pressure starts dropping again. I know its leaking through the bead because it bubbles up in 2 different spots when I cover the wheel with soapy water.
Old May 16, 2007 | 11:31 PM
gt_biker13's Avatar
Wire brushes dont get everything off. Where i work we would use a air powered buffer then use the bead sealer. Thats all that you could really do. If it still leaks then your rim could be damaged around there.
Old May 17, 2007 | 06:44 PM
driveonlycamaros's Avatar
I have the OEM chrome rims on my 94 and they leak like crazy. Prepare yourself for more pain down the road. I am looking for a painted to set and will be ditching these ASAP. Good luck. If you find a workable fix, please let me know. I was told by a GM rep they are crap (the chroming).
Old May 17, 2007 | 08:52 PM
jfv04's Avatar
It really sounds like there is no fix to this at all. I was also wondering if anybody knows of any non-chrome wheels that fit the stock tire size: P245 50 R16
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
hotrodyou1
Dec 20, 2014 10:05 PM
ithacamike
13
Sep 15, 2002 05:55 PM
Mykdiver
Aug 13, 2002 05:38 AM
RichardZ SS
Aug 3, 2002 12:26 PM
