C5 Vette Rims, will they fit?
Old Oct 11, 2006 | 03:13 PM
doo_man's Avatar
Want to buy a set of 17 x 8.5 and 18 x 9.5 rims from a C5 Vette. Anyone put these on a f-body??? Will they fit, I was told the 18 won't clear in the rear?
Old Oct 11, 2006 | 03:30 PM
Capn Pete's Avatar
Re: C5 Vette Rims, will they fit?
Yep, they'll fit . Don't get carried away with super wide tires in the back, or you "may" end up with clearance issues, requiring the BFH mod (big _ hammer). I've got 2 buddies with C5 rims on their LT1 F-bodies. One of them had problems getting the back wheels over the hub, and apparently it's a problem with earlier LT1's ..... all you "may" need to do is sand, or lightly grind out a small amount of material from the inside surface of the rim where it fits over the hub IF that poses a problem for you. Again, it's only in SOME cases, not all. But the rims should fit without needing any spacers.
Old Oct 11, 2006 | 03:46 PM
The 18x9.5" OEM rear wheels will have limited POTENTIAL problems, because the 61mm backspace gives them a 7.60" backspace.
The issue of late model wheels not fitting over the rear hubs of 96 and earlier 4th Gens is also covered in the FAQ.
Fastbird93
Apr 9, 2016 07:01 PM
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
