BS on 15X10 w/ 2.5" shortened axle (95 TA)
Old Mar 5, 2007 | 02:27 PM
maro z28's Avatar
What would be the backspacing for a 15X10 wheel on axles shortened 2.5" on each side. For a 95 trans am.
I have a suspicion of the answer, but I want to be sure. (15X10 bs-2.5??)
Old Mar 5, 2007 | 04:38 PM
Correct.... recommended BS for the 15x10 wheel on a stock axle assembly is 7.5" For a rear that had been narrowed 2.5" on each side, you would subtract 2.5", giving you a 5.0" BS requirement. If you can only get the BS in x.5" increments, it would probably be best to look at a 5.5" BS. Clearance to the inside fender liners might be tight though, with really beefy slicks.
Old Mar 5, 2007 | 05:07 PM
lethal93ta's Avatar
mine is only narrowed 2 inch's a side and I have 15x10s with 5 inch backspacing on mine 26 11.5 15 ET streets
Old Mar 6, 2007 | 12:07 AM
xpndbl3's Avatar
15x10 with 5-5.5 bs
Old Mar 6, 2007 | 02:56 PM
maro z28's Avatar
Centerline only has 3.5" or 4" bs on 15X6 telstars. i'm not 100% sure on autodrags or convo pros. It was suggested in the wheel/tire FAQ sticky to use 4.5" bs. Could 4" bs work with a spacer? Would I really NEED a spacer?
Also, 16x8, what backspace?
thanks
Old Mar 6, 2007 | 05:02 PM
What backspace works depends on the width of the wheels. But why would you be putting 15x6 wheels on a narrowed rear axle assembly?
Old Mar 7, 2007 | 07:40 AM
maro z28's Avatar
No, dude, 15X6 in the FRONT.
Old Mar 7, 2007 | 11:21 AM
I guess I was stupid enough to ASSume you were still talking about your original "topic"
Old Mar 7, 2007 | 12:47 PM
maro z28's Avatar
What interference would I run into with 4" bs on a 15x6 rim?
I just ASSumed you knew what I was talking about since YOU WROTE THE STICKY! (insert sarcastic rolling eyes-face)
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
