Black ZR-1 center caps?
Old Mar 29, 2005 | 04:04 PM
blind527's Avatar
When I get my black ZR-1's, I don't want the Corvette center cap. Can I ditch the center cap and get a black one that will fit, and put the Phoenix on it? Where do they sell these?
Old Mar 29, 2005 | 04:35 PM
Predatorbird's Avatar
Re: Black ZR-1 center caps?
get decals made from brent. http://www.bfranker.badz28.com/vinyl/vinyl.htm i got some for my wheels and they look great.
Old Mar 29, 2005 | 04:37 PM
blind527's Avatar
Do these just go over the exisiting Corvette decal? If so that would be a lot easier!
Old Mar 29, 2005 | 05:57 PM
here are pics of mine.
before:
http://memimage.cardomain.net/member...63_24_full.jpg
after:
http://memimage.cardomain.net/member.../271363_90.jpg
http://memimage.cardomain.net/member.../271363_91.jpg
Old Mar 29, 2005 | 06:00 PM
blind527's Avatar
Looks good
Old Mar 30, 2005 | 10:59 AM
Brent94Z's Avatar
Super Moderator
Thanks, Predatorbird
I have those same black ZR1 wheels What you can do is remove the adhesive "flags" of the ZR1 logo from the centercaps. This will leave a slightly indented black "ring" in the centercaps. Then what you can do is get a black vinyl disk with the bird on it. Now, under certain lighting conditions you may slightly see the indent through the vinyl. The vinyl I use is the high quality stuff which is thin. The cheap stuff is a little thicker but I don't use that stuff Doing this will be by far the easiest and least expensive. Your other option is to buy blank silver centercaps from SLP (no ring in these) and then have them painted and clear coated locally by a pro painter. At this point, all you'll need are the birds to put on your blank black centercaps. But, that'll be considerably more expensive and time consuming.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
4586
Parts Wanted
May 20, 2015 10:48 PM
R@mpage
Apr 20, 2015 10:02 AM
