Beauty or Never???
Beauty or Never???
I was really attracted of the designed pattern of SS '02 wheel rim which is 17" and I am planning to replace my Z28 '00 16" .. not for additional appearance but for "new look"
I heard that to do this, spacer or circular insert is required to avoid break-drum or my disc plate touches the inner wall of a SS 17" rim. This insert or spacer is to be located in between spoke and back of drum. Any comments or statements to this?
Regards
. I heard that to do this, spacer or circular insert is required to avoid break-drum or my disc plate touches the inner wall of a SS 17" rim. This insert or spacer is to be located in between spoke and back of drum. Any comments or statements to this?
Regards
Dear Gents,
I do have four disc brakes
!!! (IT'S NOT OPTIONAL)...thanks to you. The things that bother me most are the following: Do I need special spacer or insert to be placed in between the rim and the disc plate? Is the inner wall of the rim 17" would not touch by this plate. Should there be friction between the two, it means problem.
And should there be spacer or insert needed, any idea how thick it should be to separate them from touching? Thats what I heard about this? Would you tell me the veracity and truth about this?
thanx in advance
!!! (IT'S NOT OPTIONAL)...thanks to you. The things that bother me most are the following: Do I need special spacer or insert to be placed in between the rim and the disc plate? Is the inner wall of the rim 17" would not touch by this plate. Should there be friction between the two, it means problem. And should there be spacer or insert needed, any idea how thick it should be to separate them from touching? Thats what I heard about this? Would you tell me the veracity and truth about this?
thanx in advance
Originally posted by roadkillZ28
Dear Gents,
Dear Gents,
The wheels will fit fine - you do not need any spacers, etc.
Any '93+ Camaro wheels will fit without problem. THE ONLY thing that may be a problem ever is the center of the hub being larger on '93-'97 models - thus having to grind down the edge of '98+ wheels for them to fit - but from '98+ any wheel will fit without any problems.
Originally posted by 94BlackBowtie
The reason everyone was mentioning about 4-Wheel disc brakes is because there is no such thing as a drum with disc brakes. :blah:
Just bustin your ***** man
meissen
Aug 11, 2015 06:05 AM
May 15, 2015 10:43 AM
