Is it bad to mix tires on my camaro?
Old Jan 8, 2008 | 01:31 PM
kendall5000's Avatar
Since I am a cheapo...I am thinking about putting my rear tires (goodyear brand) which have ok tread left on the front wheels...and buying 2yokohama avs es 100 and putting them on the back...would this be ok or is it a bad idea? Thanks for the input
so i would have two goodyear all season tires on the front and two yokohamas on the back
Old Jan 8, 2008 | 09:50 PM
switch's Avatar
It's not preferable, but not a safety issue. The balance of your car will be off depending on the relative grip from front to rear. I would NEVER switch them from side to side, but as for your question, you should be ok if you have to.
Old Jan 8, 2008 | 10:35 PM
FiefSS's Avatar
Mine are different front to back, im not spending another $700 till the fronts are worn out. You will be fine.
Old Jan 9, 2008 | 01:56 AM
6SpdLT1Z's Avatar
As stated before. Not a great idea, but it will be fine.
hotrodyou1
Dec 20, 2014 10:05 PM
Hurin
Dec 13, 2014 07:38 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
