backspacing on wheels
Old Sep 20, 2005 | 09:19 PM
1970z28's Avatar
anybody running weld or centerlines wheels with {15x8 } on a 28x10.5x15 slicks. what backspacing are you useing. stock rear end. trying to keep from buying the wrong ones.
Old Sep 21, 2005 | 09:36 AM
Re: backspacing on wheels
What kind of car are you trying to put them on? Can we assume its the one in your screen name?
Old Sep 21, 2005 | 06:07 PM
1970z28's Avatar
sorry didnt even think of that. its a 94 camaro
Old Sep 22, 2005 | 08:46 AM
If you have enough power to require 28" slicks, its hard to believe you are still running the stock rear.
Whether they will fit depends on the specific tire. I've run 28" Hoosier QTP's, and they grew enough to require moving the axle backward abuot 1/4" to keep them from rubbing on the sheet metal at the front of the fender opening, when trap speed went over 120MPH. Now I've got a set of 28"x10.5-15W ET Drags, and they would not even fit in the wheel openings without taking about 1.5" off the leading edge of the rear bumper cover.
Generally, that tire would require a 10" wheel. For a 15x8" wheel, you need a 5.5" backspace. For a 15x10" wheel, a 7.5" backspace. Any less BS than that, and the tire is out from under the fender.
Click on "Trailer Queen...." in my signature.
Old Sep 22, 2005 | 10:21 PM
1970z28's Avatar
okay thanks, reason being a friend let me borrow a tire and wheel to mock up on my car to see what i would have to do. it is a 28x9x14 which fit good with about 1 1/2 inch betwen the front and rear quarter panel. it has a 86 inch circ. i see in jegs they have a 26x10x15 that has 82 inch circ.which would probaly fit better. trying to win on ebay a set of 15x10 with 6 1/2 backspacing. that much sticking out i dont think would hurt. there i go thinking again. by the way your car looks good. its only 1/8 mile 8.00 heads up raceing. probaly only about 90 mph.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
Ken Cemo
Mar 31, 2015 08:50 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
