Alignment Questions
Old Sep 27, 2005 | 07:16 PM
YARDofSTUF's Avatar
Alignment Questions
When getting an alignment done does that just straighten up the wheels, or can that move them forwad a bit?
After putting new wheels and tires on my car I knew the alignment was off, its very easy to see. But it looks like the passenger side wheel is more pushed back or closer to the wheel well.
Old Sep 28, 2005 | 05:54 AM
autoxr's Avatar
Re: Alignment Questions
That would be your caster. The caster is what moves the wheel forward or backward in the wheelwell. And yes, it can, and should be corrected.
Old Sep 28, 2005 | 06:59 AM
YARDofSTUF's Avatar
Is that done in alignments or do i need to request that, Good to hear, I was worried somethign was bent!
thanks.
Old Sep 28, 2005 | 08:12 AM
autoxr's Avatar
Yes, that's part of an alignment. Camber, caster, and toe is what they will check and correct if it's out of factory spec.
Old Sep 28, 2005 | 07:01 PM
YARDofSTUF's Avatar
thanks.
oldschool
Feb 9, 2016 09:21 PM
dfarr67
Apr 10, 2015 07:44 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
