315/35-ZR17 Tire pressure?
I just got new 17"x11" ZR1 wheels and 315/35-ZR17 BF Goodrich T/A KD tires for the rear of my car. What should my tire pressure be for normal driving. Right now I have them at 35psi.
Jason
Jason
You can't go by what is marked on the tire sidewall.... that's the pressure required to achieve the marked load rating, at max rated speed. On a 4th Gen, the 315/35-17 isn't loaded anywhere near max rating (1,874#), and the center of the tread would bulge considerably at the 44psi that is (probably) marked on the sidewall... I know that's what's on my 275/40-17 KDW's and also on my 315/35-17 Drag Radials.
I run 30-32psi in the DR's with not problems..... good traction, reasonable ride. The KD's would probably be happier at 32psi. Give it a try, paying particular attention to the tread wear. A tread depth gauge is an excellent investment when running wide, expensive tires.
Re: 315/35-ZR17 Tire pressure?
I also have Nitto P315/35/ZR17 on 10.5" rims on the rear and P245/40/ZR17 on 9.5" rims on the front of a 2002 Z28. I have been looking for guidance on tire pressure that would give even wear. This is a weekend street driven car so I am not looking for race performance. I have seen pressures quoted that range from 22 to 35 psi. Any guidance from the forum would be appreciated.
As noted above, I found 30 - 32psi to be the best for street use. The only reason you might go below that would be track use.
The 245/40-17 is a bit tricky to predict. That's a 24.7" diameter tire and 1" smaller than it should be. The rears tires are correct at 25.7". The SS and WS6 coupes for example, came with 275/40-17 (25.7") tires. Are you sure you don't have 245/45-17 (25.7")? In any case, I'd say 32-34psi would probably be best.
As noted above, get a tread depth gauge, and monitor the tread wear for evenness.
wytblur
Aug 5, 2002 02:03 PM
