315/35-17 on 9"rim, anyone???
Old 12-31-2008, 09:21 PM
  #16
Gor1la's Avatar
sorry for hijack but what difference is there between the Sumitomo HTR Z 315 vs the Nitto 315 width wise? One better then the other in this regard for a 9" ws6 rim.
Gor1la is offline
Old 12-31-2008, 10:29 PM
  #17
Published section width for 315/35-17:
BFG DR (tire in photo): 12.4" (11.0 - 12.0" wheel)
Sumi HTR-Z: 12.6" (10.0 - 12.0" wheel)
Nitto 555R: 12.1" (10.5 - 12.0" wheel)
If you believe the published numbers, the Sumi would be a bigger problem than either of the other tires on a 9.0" wide wheel. You sort of have to give the engineers who designed the tires credit for knowing what size wheel its supposed to be mounted on.
Injuneer is offline
Old 01-07-2009, 05:23 PM
  #18
wyldcdn's Avatar
i "had" 315's Nitto555R's on my zr1 17x9.5's Slight outer buldge on side wall. Tires were free so no biggie. Here's where I had a problem. No matter what air preasure I ran....I could not get the center tread to spread out. It always cupped inwards/upwards. Leaving heavy outer black marks and barely noticable center black marks. I had better traction running the 275 nitto 555R's. I purchased a set of 17x11's brand new for a great price of 110.00 each. Figure I can mount my extra set of nitto 275's on the 17x9.5's and keep em for track use. Now positive side of it all. I never had any ill handling problems or rubbing problems. Just less traction due to the cupping.
wyldcdn is offline
Old 01-08-2009, 11:30 PM
  #19
Highlander's Avatar
hm... so in the end its not recommended to use the 315s nittos on the 9.5" wheel?
Highlander is offline
Old 01-09-2009, 02:34 AM
  #20
AutoRoc's Avatar
Um....several people said they did it with no issues...they even provided pics for verification...I'm also saying it's ok as I did it...pics are on website...THE ONLY 315 YOU CAN PUT ON A 9-9.5" RIM IS A NITTO DRAG RADIAL. IT'S A DAMN ODDBALL TIRE THAT'S SKINNIER THAN ADVERTIZED.
At the track, run them at 20psi and smoke them A LOT. goodluck
AutoRoc is offline
Old 01-09-2009, 07:01 AM
  #21
wyldcdn's Avatar
no issues if you remove the center area no being 100% in contact
*ignore the bald section; they were like that when they were donated to me*
wyldcdn is offline
Old 01-09-2009, 07:11 AM
  #22
wyldcdn's Avatar
I never realized til I was in the market how much narrower a 315 nitto is. Its closer to a reg 275
wyldcdn is offline
Old 01-11-2009, 11:03 AM
  #23
cammed SS's Avatar
My car had the sumo. 315's on it when I got it and the sidewalls were caved inward towards the rim. Ive got zr1 17x9's. Stay away from this brand THEY SUCK I currently have this brand 275/40/17's all the way around and cant hook for ****.
cammed SS is offline
Old 01-11-2009, 11:08 AM
  #24
wyldcdn's Avatar
thanx...noted..sumo's SUCK
wyldcdn is offline
G-BODYT56
01-14-2022 11:14 PM
IndyZman
10-22-2015 02:17 PM
Formula Steve
09-19-2015 08:48 PM
rvonsternberg
09-14-2015 11:58 AM
scottcba1
09-08-2015 09:52 AM
Quick Reply: 315/35-17 on 9"rim, anyone???
