315/35-17 on 9"rim, anyone???
#17
Published section width for 315/35-17:
BFG DR (tire in photo): 12.4" (11.0 - 12.0" wheel)
Sumi HTR-Z: 12.6" (10.0 - 12.0" wheel)
Nitto 555R: 12.1" (10.5 - 12.0" wheel)
If you believe the published numbers, the Sumi would be a bigger problem than either of the other tires on a 9.0" wide wheel. You sort of have to give the engineers who designed the tires credit for knowing what size wheel its supposed to be mounted on.
#18
i "had" 315's Nitto555R's on my zr1 17x9.5's Slight outer buldge on side wall. Tires were free so no biggie. Here's where I had a problem. No matter what air preasure I ran....I could not get the center tread to spread out. It always cupped inwards/upwards. Leaving heavy outer black marks and barely noticable center black marks. I had better traction running the 275 nitto 555R's. I purchased a set of 17x11's brand new for a great price of 110.00 each. Figure I can mount my extra set of nitto 275's on the 17x9.5's and keep em for track use. Now positive side of it all. I never had any ill handling problems or rubbing problems. Just less traction due to the cupping.
#20
Um....several people said they did it with no issues...they even provided pics for verification...I'm also saying it's ok as I did it...pics are on website...THE ONLY 315 YOU CAN PUT ON A 9-9.5" RIM IS A NITTO DRAG RADIAL. IT'S A DAMN ODDBALL TIRE THAT'S SKINNIER THAN ADVERTIZED.
At the track, run them at 20psi and smoke them A LOT. goodluck
#23
My car had the sumo. 315's on it when I got it and the sidewalls were caved inward towards the rim. Ive got zr1 17x9's. Stay away from this brand THEY SUCK I currently have this brand 275/40/17's all the way around and cant hook for ****.
