315/30/18 Will it fit?
Old Oct 11, 2004 | 04:59 PM
93Z286Speed's Avatar
18x10.5 wheel with a 58 mm offset will a 315/30/18 tire fit without issues?
Old Oct 11, 2004 | 09:05 PM
Re: 315/30/18 Will it fit?
id like to order tires some what soon, and i wanna know if i should get the 315s, or just get the 295's
Old Oct 12, 2004 | 09:00 AM
im going to assume noone knows the awnser to this
Old Oct 12, 2004 | 09:36 AM
Definitely a good chance its going to rub the inside edge of the tire on the inner fender liner. That wheel has an 8.0" backspace.... that's slightly more backspace than the typical 17x11 50mm offset wheel (7.93"). Gonna be close. Be sure to check the outer edge of the jounce bumper bracket. It can catch the inside of the wheel with the axle at full drop, requiring that you support the axle, rather than the body when putting the wheel on the car. Alternatively, you can cut/grind the edge of the bracket off.
Old Oct 12, 2004 | 12:59 PM
im going to lower the car 1.5 inches too, should i just get the 295s to be safe? or chance the 315s?
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
