3.42 gear and tires?
Old Jan 9, 2006 | 08:14 PM
ddrake84's Avatar
Question 3.42 gear and tires?
Ok guys i need some tire help bad. I have a 3.42 gear in my z, and its needing new tires. I know there is a similar post on here from someone with a 4.10 gear, but i was just wondering whats best with mine? I want a tire that has a lot of bite to it, with just a little bit of slip. Suggestions? Thanks in advance.
Old Jan 9, 2006 | 09:11 PM
Greed4Speed's Avatar
Re: 3.42 gear and tires?
tirerack.com
Old Jan 10, 2006 | 08:09 AM
I would assume you are after as much dry traction as you can get. The tire choice isn't going to vary all that much with gear ratio. Yes, if you are running 4.10's maybe you just can't get enough from a "street tire", so you are forced to consider sticky drag radials. You get the increased traction, but are limited on wet traction and tread life.
But I think its a stretch to assume you can pick a specific tire based on the fact that a car has 3.42 gears. More important than that would be what kind of power/torque those tires are being asked to transmit to the pavement, and what kind of drivetrain (A4, M6, high stall converter, etc) is being used to carry that power to the back wheels.
blac94Z
Mar 6, 2015 07:55 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
SLIMJIM
Jan 7, 2003 11:06 AM
x7x7
Aug 15, 2002 06:49 PM
Viper
Jul 30, 2002 02:06 AM
