28inch tire 15X8
Old Apr 11, 2006 | 11:59 PM
YZF/LS1 Freak's Avatar
28inch tire 15X8
Picked up a set of Pro Stars 15X8 in the back on Bridgstone skinnies and 28 inch M/T E.T. streets in the back.
Came off of a 83 Z and after looking at the wheel well of it, my 96 and my old 86 I am pretty sure they are all the same. Its a tight fit on the 83 but its the same well for third and fourth gens right?
Just gotta get the grinder out now
Old Apr 12, 2006 | 01:53 AM
Evil Eric's Avatar
Re: 28inch tire 15X8
you can get 28"s on there, seems like I read a writeup on it and the guy just clearenced his wheelwell with a 2.5 pound sledge to make sure he had 1" clearance from the side of the tire. I do remember it was for an auto-x car so he might have been doing that for sidewall clearance in tight cornering or something.
Old Apr 12, 2006 | 08:37 AM
If its an ET Street 28/11.5-15 it will fit, because its only 27.6" diameter. The wider 28's (12.5) are larger diameter and may be a problem fitting in the wheel openings, particularly when they grow at high speeds.
What is the backspace of the 15x8" wheel? For a 4th Gen, you need a 5.5" backspace to keep the tire under the fender. A 3rd Gen would typically use 1" or 2" less backspace.
Old Apr 12, 2006 | 10:30 PM
From the base of the wheel (were stud hole are) to the outside lip it was 4 1/4 if I remember right. On his car they were under the fenders but at the bottom they stuck out.
PLEASE don't tell me I am screwed....
Old Apr 12, 2006 | 11:25 PM
elevensecondv6's Avatar
Surely someone on here can tell the man for sure.Anybody run them on their car before???Seems like I talked to a guy that had the same setup on his car and they fit.
Old Apr 12, 2006 | 11:32 PM
Injuneer should be able to tell me, Pro Stars are the wheel of choice here lol.
Oh, I just farted, farted under you car also....
Old Apr 12, 2006 | 11:48 PM
Injuneer had that fast car that I should have bought I think.
Old Apr 12, 2006 | 11:56 PM
Or was selling it, drop top LT1 camaro with to much HP lol.
Old Apr 12, 2006 | 11:58 PM
It was a nice car.I should have bought it.
Old Apr 13, 2006 | 08:10 AM
A third gen has a rear axle assembly that is 3" narrower than a 4th Gen. That's why you need a wheel with 1.5" more backspace on a 4th Gen.
This is where the tire will site on an 8" wide wheel with a 5.5" backspace:
Yours will stick out 1.5" more than that.
(Those are actually 10" wide wheels with 7.5" BS, but that puts the outside edge of the tire the same place as the 8" wide 5.5" BS wheel.)
Old Apr 13, 2006 | 05:57 PM
350lsi's Avatar
i own a 98 z28 and have 15x8 draglites with 275/60/r15 which is 28'' tall and they will rub fender when you get on it but that can be easily fixed no problem
Old Apr 14, 2006 | 12:06 AM
I am going to look like a homo......
All well, Ill get some new ones later this year or something, I got a good deal on them so I can't complain.
Not worried about rubbing, gonna to some modifing to the well before I put them on and join homo vill.
Old Apr 14, 2006 | 12:08 AM
You already look like a homo.......
Old Apr 14, 2006 | 12:18 AM
One day I am going to leave a flaming bag of poop on your front step.... :P
Old Apr 14, 2006 | 12:20 AM
You would too wouldn't you.
