275 Nitto 555R on 8.5" wheel?
Old Mar 21, 2006 | 08:58 AM
Mr.Whitey's Avatar
Anybody running 275 Nittos 555R tires on a 8.5" wheel? Nitto lists the approved rim width as being 9-11" for the 275/40/17. Will there be any issues running a wheel under the approved width? For those using the 275/40/17 555R on a 8.5", do you have any pics of the sidewall?
Old Mar 21, 2006 | 09:15 AM
JakeRobb's Avatar
Super Moderator
Re: 275 Nitto 555R on 8.5" wheel?
275mm = 10.82"
That's a 2.32" difference between the wheel and tire, so 1.16" on each side. A 275/40 has 4.3" of profile height, and if you do the trig, that comes out to 15 degrees overall sidewall angle. That doesn't account for the crown of the tire, so the actual angle would be more.
You're right to question it. I don't think I'd do it. I'm guessing you already have the wheels, right?
Old Mar 28, 2006 | 11:28 AM
Jim85IROC's Avatar
275s come stock on 9" wheels. How bad could it be on a wheel a half inch narrower? That's only 1/4" for each sidewall.
Old Mar 28, 2006 | 02:17 PM
DWray's Avatar
I run 'em with no problems on an 8" wheel.
Old Mar 28, 2006 | 03:01 PM
Mr.Whitey's Avatar
What size wheel are the wheels & tires? Pics?
Old Mar 28, 2006 | 05:58 PM
DWray's Avatar
17x8 American Racing TTII's with 275/40/17 Nitto 555R's (I now have ES100's in the same size).
Here's a picture of when I was running the Nittos.
Here's a closer shot I just dug up.
Old Mar 28, 2006 | 06:08 PM
Mr.Whitey's Avatar
That sidewall looks OK in the pics....and these wheels would be 1/2" wider than in the picture, NICE. It seems to be worn more in the middle of the tire, is that the normal wear to be expected with the Nittos?
Thanks for the pics!
Old Mar 28, 2006 | 06:18 PM
Cmr0z28's Avatar
275/40/17 555Rs will fit fine on an 8" wheel. They run smaller than most tires.
sloppytot
Feb 25, 2015 08:30 PM
Jason Short
Jan 19, 2015 06:33 PM
Starz2000ss
Oct 19, 2003 09:05 PM
CARGASM
Sep 4, 2002 11:17 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
