255 Recommendations.
Old Mar 3, 2008 | 01:42 PM
Melee Penguin's Avatar
Hello Wheel & Tire people
I've got the stock 16s on my Z28 and eventually will go to 18x10 CCW 505As, BUT in the meantime I would like to get some new tires before a road trip in May from Nor Cal to Dallas Tx.
I've skimmed through the wheel & tire faq and would like some recommendations for tires in the 255 range. It's Northern California, so I don't need all weather tires, but I'd also like to get some life out of them as I daily drive the Z.
So my main draw is tread life, but I've got a brother in law that wants to race when I get down there, so I'd also like some pretty performing tires.
Any suggestions in the 255 range?
Old Mar 3, 2008 | 04:17 PM
Although some people find fault with the user feedback data on Tire Rack, because its often from people who aren't too sharp, or have little experience with tire selection, its still a rough guide to things like dry traction and tread life, which appear to be your priorities.
If you put 255/50-16 in as the tire size, and go to the listing of tires, they will offer you the opportunity to click on a comparative table for a large number of tires, that shows the feedback ratings, from 0-10, for each characteristic like wet traction, dry traction, noise, ride quality, handling, tread life, etc. That will point you in the direction of what is the best combination of the factors you consider important. The list of tires available in that size also offers you the opportunity to sort by cost.
Old Mar 3, 2008 | 10:15 PM
sn8ke eatr's Avatar
some nitto drag radials will give good tread life for a drag radial, but maybe not as good as you are looking for
Old Mar 6, 2008 | 08:28 PM
Kaj's Avatar
Kaj
I'd recommend the Goodyear Eagle F1 or the BFG KDW II
Old Mar 6, 2008 | 10:23 PM
Might be able to toss this whole thread out the window
https://www.camaroz28.com/forums/sho....php?p=5229285
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
Speeds8erM-1
N2O Tech
Oct 15, 2002 05:25 PM
