235/45/17 on cragar s/s rims- rides rough
The 98 z28 i just got came with 235/45/17's on cragar s/s rims. I think the tires are kumho proxess(?) anyway the car rides like it has no suspension at all. If the shocks are worn out would they get stiffer? When ever i have had bad shocks before they just got sloppy and loose. Also the tires seem a bit narrow for the car. The rims look preety sweet i guess but i would love to trade with someone for stock rims. Maybe i can find someone locally that will do it,lol. Any recomandations as far as what size 17" tire i should put on and brand?
Re: 235/45/17 on cragar s/s rims- rides rough
How wide are the Cragar SS wheels?
What inflation pressure are you running in the tires?
The tire is not only "narrow", its smaller in diameter than the stock tires.
The max pressure is for a max load rating for that tire. Read the rest of what is said on the tire. For instance it might be 1500 lbs. No way the tire is carrying that much weight. Run the pressure that is on the drivers side door. It is probably around 30 lbs.
