19 x 10 Boze
Old May 28, 2007 | 12:04 PM
JustNO's Avatar
19 x 10 Boze
My 19 x 10 Bozes just arrived. I did a deep research, but couldn't find a solution.
What should be my tires?
I think for the rears it will be 285/30/19, but I couldn't find for fronts. According to the calculators it should be 245/35/19, but it CAN'T be because of the 10" wide. Any opinion?
Chucky are you still here? : )
Old May 29, 2007 | 08:16 PM
4SFEDZ's Avatar
i would go with a 295/30 or 35, i ran 295/35 on a 9.5 and it looked good, 10 would look even better!!! look in sig and the pewter car has the 19x9.5 with 295/35/19 in the rear
Old May 29, 2007 | 10:26 PM
Why did you buy 10" wide wheels for all four corners, knowing that you wanted to run a narrow tire in the front? It would seem to make more sense to but a narrower wheel for the front if you want to run a narrower tire.
Old May 30, 2007 | 06:57 AM
JustNO's Avatar
The problem was about manufacture. I had 2 choices 19 x 8" or 19 x 10", If I want to go with 19 x 9", The wheel should be 3 pieces ($$$$$$$$), So I choosed 19 x 10" for fronts too.
Any suggestion about the size? I tought 265/35/19 for fronts, I think I can't go with narrower than that right?
Old May 30, 2007 | 08:49 AM
shock6906's Avatar
I'd see if you could return a pair of the 19x10's and trade them for a pair of 19x8's for the front. That way you could run the narrower tire and have less risk of rubbing the tire every time you go around a corner.
Old May 30, 2007 | 10:29 AM
4SFEDZ's Avatar
I Would Do The 8 In Front Also!
Old May 30, 2007 | 11:00 AM
JustNO's Avatar
Hmm the thing is, I can't send the wheels back cause I'm from different country. So that sucks
Old May 30, 2007 | 01:56 PM
shock6906's Avatar
I'm sure you could, but it would cost an arm and a leg most likely to send them back and have replacements sent to you. Which wheel is it? I'd like to see what they look like.
Old May 30, 2007 | 02:18 PM
JustNO's Avatar
I wanted to post pictures after I put them on the car, but here they are;
Old May 30, 2007 | 02:19 PM
JustNO's Avatar
What is the minimum tire wide can we put on the 10" ??
Old May 30, 2007 | 02:53 PM
shock6906's Avatar
That's a nice looking set of wheels. They should look great on the car.
Old May 30, 2007 | 02:58 PM
JustNO's Avatar
Thanks. The first one is the front (1.5" lip), and the second one is rear (3" lip).
Old May 30, 2007 | 03:43 PM
shock6906's Avatar
Well I hope you get the reccommendations you need so you can get some tires on them. I can't wait to see pictures of the car with the wheels installed.
Old May 30, 2007 | 06:29 PM
You shouldn't go below a 265mm section width. You will be looking at 265/30-19 (a bit smaller than stock diameter) or 265/35-19 ( larger than stock diameter).
What tire fits on what wheel width is determined by the tire manufacturer, and can vary by manufacturer, or even among different models of tires from the same manufacturer.
Old May 30, 2007 | 06:43 PM
AdioSS's Avatar
West South Central Moderator
with expensive wheels like that, I would go with slightly taller tires to protect them a little more.
They look nice!
