17x9.5 tire size
Subscribe
Feb 1, 2013 | 10:49 PM
I drive a 2002 Z28 and was planning on purchasing some 17x9.5 wheels. Question is, what size tire would be ideal for this wheel size and will spacers be needed? Thanks!
Reply
Feb 2, 2013 | 01:09 AM
Re: 17x9.5 tire size
my 96 is running 17x9.5 s up fro t and im running. 275-40-17s... my rears are 18. no spacers for up front...but remember the wider the tires...the more the car will be apt to track on the roadways
Larry (Popo8) Co-owner
LTXtech.com
Reply
Feb 2, 2013 | 11:31 AM
Whether you need "spacers" will depend on the offset of the wheels. If you buy 17 x 9.5" wheels with an offset in the range of 45 - 56mm you will not have any problems.
These are 17 x 9.5 49mm offset wheels with 275/40-17 tires:
http://www.injuneer.com/images/photos/210Full02a.jpg
These are 17 x 9.5" 56mm offset wheels (front only) with 275/40-17 tires:
http://www.injuneer.com/images/photo...a/DCP02767.jpg
For tires, to avoid throwing the speedometer off, match the stock tire diameter. If your car had the 245/50-16 Z-rated tires, the 275/40-17 is the perfect diameter match. If your car had the base 235/55-16 tires, a 285/40-17 would be a better diameter match. With a 45mm offset, and the 285 tires, you might get some minor rubbing on the plastic fender liners in the front when the steering wheel is at full lock.
A tire diameter mismatch can also be addressed by reprogramming the tire diameter in the PCM program.
Reply
Feb 3, 2013 | 08:50 PM
I run 285s, no spacer.
Reply
Feb 3, 2013 | 09:39 PM
17x9.5 tire size
Thanks guys. I was concerned about the tires rubbing.
2002 Camaro Z28
Flow master exhaust
Alpine Type R 12's
Hifonics BRZ2100.1D
Reply
Subscribe
