17x9.5 on front?
Old Aug 9, 2005 | 07:10 PM
csucguy18's Avatar
17x9.5 on front?
Will 17x9.5 rims fit w/o rubbing on the front of a 4th gen camaro? tires are 235/45/17
Old Aug 9, 2005 | 09:00 PM
kameleon426's Avatar
Re: 17x9.5 on front?
yes they should fit, im currently using 275/40/17 up front and my car is lowered.
Old Aug 9, 2005 | 10:21 PM
SUTTERERMAN85's Avatar
yes, but make sure they have a 56mm offset. you can run a 275/40/17 also if you want like said above
Old Aug 10, 2005 | 09:08 AM
Th 17x9.5" wide wheels will work with anywhere from a 45mm to a 56mm offset.
A 235/45-17 tire will NOT work on a 9.5" wide wheel. Most manufacturers only recommend thm for wheels 7.5-9.0" wide. They are going to look "stretched" on a 9.5": wide wheel, and leave the edge of the wheel open to curb damage. The only good choices for a 9.5" wide wheel would be the 275/40-17 or 285/40-17.
Old Aug 12, 2005 | 12:15 PM
Dave '97 Z28 M6's Avatar
I found that a little "bump" on the front suspension arm interfered with the wheel weights on the back rim of my 17x9.5 +56mm ZR1's. A couple of minutes with a grinder and the problem was solved.
Old Aug 12, 2005 | 12:58 PM
Were the weight clipped to the edge of the rim? Or were they taped to the inside? The 56mm wheel is so close to the knuckle that a clip-on weight would probably rub, but I don't know of anyone that wants clip-on weights on an alloy wheel.
Old Aug 14, 2005 | 11:04 AM
Yes they were clip-ons, Fred. That's how they were when I got them.
96SilverRam
Nov 20, 2016 11:19 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Bobczar
Oct 23, 2015 11:22 AM
8T8IROC
Mar 26, 2015 09:02 PM
